Problem with Medion Akoya s15449
3 RÉPONSES 3
eraifmik
Message 1 sur 4
2 491 Visites
Message 1 sur 4
2 491 Visites
Hello ..
I am a designer and programmer & I currently own ( MEDION AKOYA S15449 (MD 63955)
It's a very new device (But there is a big problem with the screen) When starting up and the appearance of the Medion logo on the screen, I noticed the appearance of a shadow, but a glowing yellow-white color, centered at the edges of the screen in all four directions, and also appears only on black backgrounds.
I noticed this from the first moment I bought the device
I love black color and black backgrounds.. this is very annoying
What is this, is this normal?
Thanks you,,
Balises (1)
3 RÉPONSES 3
mats749
Message 2 sur 4
2 480 Visites
Message 2 sur 4
2 480 Visites
Hi Eraifmik,
Welcome to the community!
Without seeing the screen, I couldn't say for sure, but it sounds like you're describing Back-light bleed. certain amounts of backlight bleed are normal due to the nature of the screens and how they work. You could try and turn the brightness down a little and see if it makes a difference however, normally there is no way of preventing it.
If you do feel like its excessive, Id recommends contacting your local Medion service center
Thanks
Mats749
eraifmik
Message 3 sur 4
2 452 Visites
Message 3 sur 4
2 452 Visites
MEDION AKOYA S15449 (MD 63955) MSN: 30032181
What is this, is this normal?What is this, is this normal?
mats749
Message 4 sur 4
2 437 Visites
Message 4 sur 4
2 437 Visites
Hi Eraifmik,
Id certainly recommend contact your local medion support to have this looked at.
You can contact medion support via the website here
Thanks
Mats749
3 RÉPONSES 3
