am 23.01.2019 22:40
am 23.01.2019 22:40
Hi
I'm trying to find a replacement cable for the display. Is it listed here https://www.medion.com/medionserviceshop/search?sbf=true&sfs=1&msn=30015318 ? If so, which one is it? If not where can I get a suitable replacement cable?
Many thanks!
Ray
am 24.01.2019 01:18
am 24.01.2019 01:18
Hallo @rayishappy
This notebook is from 2013 because you have no chance to maybe look at eBay
Gruß Raymond
am 24.01.2019 09:23
am 24.01.2019 09:23
Hello @Raymond
Thank you for your reply.
Is any of the 2 internal cables listed on https://www.medion.com/medionserviceshop/search?sbf=true&sfs=1&msn=30015318 (MSN: 40041206 and MSN: 40041209) the cable I need?
If not, when I search on Ebay, do you know if any other laptops use the same cable as my P6518?
Many thanks!
am 30.01.2019 10:27
