Medion Erazer Deputy P60 - USB-C specs?
2 ANTWORTEN 2
dooties
Nachricht 1 von 3
1.494 Aufrufe
Nachricht 1 von 3
1.494 Aufrufe
Hi there,
for a: Medion Erazer Deputy P60 MD 62591 (UK)
MSN 3003 6528
Was hoping for some clarification please, do the USB-C ports support DP alt mode?
Planning to use a dock to connect a monitor and other peripherals.
Any clarification is muchly appreciated,
Cheers
2 ANTWORTEN 2
dooties
Nachricht 2 von 3
1.480 Aufrufe
Nachricht 2 von 3
1.480 Aufrufe
Ended up phoning product support, they confirmed the USB-C port supports DP Alt-mode. (Take it with a pinch of salt though as agent did not sound too sure).
Thanks 🙂
Nachricht 3 von 3
1.472 Aufrufe
Nachricht 3 von 3
1.472 Aufrufe
@dooties
He should have declared which USB port.  On the  left or right side of the laptop?
I do not think so. The NB has a dedicated Mini Display Port und the right side ( siehe picture in the manual) next to  a USB Port 3.2, Gen 2  (type C) .
So why should the USB C-port supports an DP alt. mode?
But who knows, look in the specs of the mb at Clevo.
--> https://www.medion.com/de/service/product-detail/30036528
2 ANTWORTEN 2
