Medion Erazer Control Center
8 REPLIES 8
nigel2392
Message 1 of 9
Message 1 of 9
Hello! I have a medion Erazer P7647 with MSN 30024622.
I have recently bought this laptop, secondhand, and I find that there is no Medion Erazer Control Center. Is it possible to get a download for it somewhere? Or against a payment?
8 REPLIES 8
Gehringer
Retired
Message 2 of 9
Message 2 of 9
Hi @nigel2392 , and welcome to the FORUM!
there are some topics on Forum about this same issue.
Please refer to this one here for instance.
Regards,
Gehringer
nigel2392
Message 3 of 9
Message 3 of 9
Hey! Thanks for the reply! 🙂
I have checked the forum for download links or additional information, but those sollutions don't really seem to work.
As I click the link in that topic, I get a 404 not found error, so the link unfortunately doesn't work. I have installed the control panel from ww1.medion.de, however without luck. I get an error that it isn't compatible with my mainboard. Could I maybe buy a hard drive from Medion that has all the OEM apps installed?
Gehringer
Retired
Message 4 of 9
Message 4 of 9
Hi @nigel2392 ,
have you tried factory settings reset?
It should reinstall all the APPs that came pre-installed.
Regards,
Gehringer
nigel2392
Message 5 of 9
Message 5 of 9
Ahh, I'm sorry I should have clarified so save time. Yes, I have tried, but there are unfortunately no apps in the recovery folder. No OEM apps at least, only windows bs so to say.
Gehringer
Retired
Message 6 of 9
Message 6 of 9
Hi @nigel2392 ,
hmmm... have you checked if you have the latest motherboard update version installed?
Regards,
Gehringer
nigel2392
Message 7 of 9
Message 7 of 9
Yes, I have, the motherboard version is 2.11, I was looking for bios updates but I'm very careful with what is and isn't compatible, so I decided not to download the  2.22 version because I wasn't sure if my MoBo was compatible with it, as it didn't specify it was compatible.
Gehringer
Retired
Message 8 of 9
Message 8 of 9
Hi @nigel2392 ,
I think this link here may work.
Regards,
Gehringer
nigel2392
Message 9 of 9
Message 9 of 9
Ahh, I was more hoping for OEM software where I can change fan speed and such, I appreciate the help tho!
8 REPLIES 8
