Installed drivers from USB. MSN 30039294
1 ANTWOORD 1
JonasAd
Bericht 1 van 2
473 Weergaven
Bericht 1 van 2
473 Weergaven
I needed to reinstall the OS because I had on Bitlocker. After it finished, I then transferred the drivers I downloaded from your website and transferred them to a USB.
Driver Package MEDION E172x3/E174x3 Notebook Series
Above you can see the drivers that I downloaded. So those are the drivers for MSN 30039294
I installed these drivers from the USB stick, I didn't transfer them to the computer first, but they were installed from the USB stick. Just want to be sure and ask if it makes a difference if you do it this way or if I should transfer them to the computer first?
I think that the drivers are not installed on the USB stick, they are installed on the computer even though you install them from the USB stick?
Asking you because I had problems when I did that another time, otherwise I know that they are usually installed on the computer if you run them from a USB stick. Just want to be sure.
Best regards.
1 ANTWOORD 1
Bericht 2 van 2
470 Weergaven
Bericht 2 van 2
470 Weergaven
@JonasAd
Das Betriebssystem braucht die Treiber, nicht ein USB Stick. In den Install-Befehlen wird der Pfad zum Betriebssystem angegeben, nur dort können die Treiber landen. Egal ob du vom USB Stick oder von einer internen Festplatte aus installierst.
Gruß, daddle
1 ANTWOORD 1
