Erazer X7851
13 ANTWORTEN 13
WhateverOverIt
Nachricht 1 von 14
9.048 Aufrufe
Nachricht 1 von 14
9.048 Aufrufe
Erazer X7851
I appear to have suddenly lost the control centre that allows me to change the keyboard backlight and it has reverted to blue.
It's not the first time this has happened and on previous occassions I've managed to fix it after spending way too long googling and trying everything. This time though I cannot figure it out.
I downloaded the correct control centre (I think) but still nothing works and the control centre doesn't even show as installed.
I'm seriously pulling my hair out here, can someone please help?
Thank you
13 ANTWORTEN 13
Nachricht 2 von 14
6.366 Aufrufe
Nachricht 2 von 14
6.366 Aufrufe
Hello @WhateverOverIt  and welcome
did you uninstall the old control center first?
which version did you reinstall? the version of drive d :/recover or from the medion service page:
https://www.medion.com/gb/service/product-detail/30025239
download/extract the zip file and install.
bye Fishtown
WhateverOverIt
Nachricht 3 von 14
6.359 Aufrufe
Nachricht 3 von 14
6.359 Aufrufe
Thank you so much for responding Fishtown.
At the risk of sounding like a complete muppet I'm going to be completely honest. I have downloaded so many different things now I don't know what I've done.
I found something on this forum that told someone else to reinstall from the drivers. I followed what they did but the only control centre showing did not say Erazer control centre.
I do believe I've downloaded zip files and the one from that link in your initial response. Should I try again?
WhateverOverIt
Nachricht 4 von 14
6.354 Aufrufe
Nachricht 4 von 14
6.354 Aufrufe
So I just downloaded the zip file from your link and installed it.
Laptop was restarted, Should I now have a way to access it because I'm seeing nothing.
Thanks again
Nachricht 5 von 14
6.349 Aufrufe
Nachricht 5 von 14
6.349 Aufrufe
hello @WhateverOverIt
if everything went well you should be able to open the control center with Fn+ESC.
bye Fishtown
WhateverOverIt
Nachricht 6 von 14
6.344 Aufrufe
Nachricht 6 von 14
6.344 Aufrufe
Sadly that would make life too easy. I've tried fn+esc but nothing happens.
I uninstalled the control centre and reinstalled the correct one - nothing.
I truly am at a loss and previous times I suspect it was a fluke that I managed to get it back. I don't even know what made it stop working in the first place.
Absolutely doing my nut in now
Thank you for any advice you can offer
WhateverOverIt
Nachricht 7 von 14
6.343 Aufrufe
Nachricht 7 von 14
6.343 Aufrufe
I also don't have that icon to click in the taskbar - or anywhere.
Nachricht 8 von 14
6.336 Aufrufe
Nachricht 8 von 14
6.336 Aufrufe
hello @WhateverOverIt ,
just to be sure:
did you extract the folder before the installation? that's important, that's the only way it works properly
bye Fishtown
WhateverOverIt
Nachricht 9 von 14
6.332 Aufrufe
Nachricht 9 von 14
6.332 Aufrufe
Hi Fishtown.
Yes, i extracted all. I then clicked the setup application in the 2nd folder? there were 2 folders but the 3nd one seemed to be a newer application.
I've still got nothing.
Nachricht 10 von 14
6.328 Aufrufe
Nachricht 10 von 14
6.328 Aufrufe
Hi @WhateverOverIt
sorry for asking again, but did you take the right folder (file folder)?
there the cc comes first.
bye Fishtown
can you find the control center in the control panel under installed programs?
13 ANTWORTEN 13
