E7214 Cant turn wifi on.
4 REPLIES 4
Rincewind
Message 1 of 5
Message 1 of 5
I just cant get wifi to turn on.
BIOS options are Off or Last State
Device manager says wifi card (Realtek RTL8192=1SE) is enabled and working properly
Drivers are up to date
Control Panel->Network->Wirless Connection->Enable but wifi has a red cross
Task Bar wifi has a red cross
Windows mobiity centre (Win+X) has wireless shown as off and 'Turn On' is greyed out
Troubleshooting Diagnose always says "Use the switch or Function Keys if available"
F7 has the wireless symbol and does nothing (regardless of whether Fn Key is pressed)
The only hot key that do anything are F4 (alternate screen) or F5 (volume off) So maybe the hotkey software is not installed. Where can I find it?
Any suggestions welcome
Tags (2)
2 ACCEPTED SOLUTIONS
Message 2 of 5
Message 2 of 5
@Rincewind
What ist the status of WiFi in device manager?
Hi Rincewind, did you install the Launchmanager? It contains the Hotkey App.
Check in C:\ Program Files (x86) \ Launch Manager \ HotkeyApp.exe,  if it is there.
The Launch Manager and all Drivers can be found here.
--> https://www.medion.com/de/service/product-detail/30011417
Installed the Fn F7 combination switches the WiFi card on and off
To make sure name the MSN Number of your machine. You find it on a sticker on the bottom of the case.
Rincewind
Message 3 of 5
Message 3 of 5
Thanks.
Couldnt find it anywhere
4 REPLIES 4
Message 2 of 5
Message 2 of 5
@Rincewind
Rincewind
Message 3 of 5
Message 3 of 5
Thanks.
Message 4 of 5
Message 4 of 5
@Rincewind
@Rincewind  schrieb:
Thanks.
Welll, it was there definitely  in the beginning. Did you upgrade from Windows 7 to Windows 10, or replaced the original installation with a new Install of Windows 7 ?
And did you succed with the launchmanager?
Rincewind
Message 5 of 5
Message 5 of 5
yes thanks.
Got PC with Win10. Reinstalled Win7 hence no Launch Manager
Now I cant get it to sleep/hibernate but I'll start a new post
4 REPLIES 4
