E3221 - MD 62116, power supply replacement?
1 REPLY 1
Stefano69
Message 1 of 2
Message 1 of 2
Hi all
i have an old mediocre computer. I have lost the charger and wanted to buy a replacement
I have found a charger on Amazon. Output is 19V however on the back of my laptop wheee the model number is repeated, it’s clearly mentioned I put 12V. I am a bit confused. Does this model have different sub models with different power supply needs? What is the right one for my laptop? Thanks
1 ACCEPTED SOLUTION
Message 2 of 2
Message 2 of 2
1 REPLY 1
Message 2 of 2
Message 2 of 2
@Stefano69
You do need a 12 V charger. Look here, scroll  down.
https://www.medion.com/medionserviceshop/de/p/gehause-cnb-e3221-medion-md62116-it-30031044
Cheers, daddle
1 REPLY 1
