E15407: Is is possible to adjust volume without pressing Fn key?
2 ANTWORTEN 2
mark8chiro
Nachricht 1 von 3
758 Aufrufe
Nachricht 1 von 3
758 Aufrufe
It's annoying to have to press 2 buttons to adjust the volume and mute, can it be changed please?  I'm not expert at detailed things on computers
Nachricht 2 von 3
686 Aufrufe
Nachricht 2 von 3
686 Aufrufe
hello @mark8chiro  and welcome
Take a look in the BIOS to see if you can reverse the function there. After restarting, hold down the F2 key to enter the BIOS.
If it's like my E16401, you can exchange Standart F1-F12 mode and Special function mode under Advanced
Note: I can set it like this on mine, but it doesn't work yet, that's still being clarified. If you're interested, here's the article.
https://community.medion.com/t5/Notebook-Netbook/Tastaturbeleuchtung-dauerhaft-aktiv-setzen-Akoya-S1...
But since you have a different bios, it might work for you.
bye Fishtown
Alternatively, you can also
At least control the volume + brightness at the bottom right of the desktop image with the touchpad mouse without using fn+.
2 ANTWORTEN 2
Nachricht 2 von 3
687 Aufrufe
Nachricht 2 von 3
687 Aufrufe
bye Fishtown
mark8chiro
Nachricht 3 von 3
646 Aufrufe
Nachricht 3 von 3
646 Aufrufe
Thank you  so much, that worked perfectly!  As a non techy person I was able to follow your instruction easily.  I already knew I could use the icon in the toolbar, but it's so much quicker to use a key
2 ANTWORTEN 2
