E15301 m.2 support
5 ANTWOORDEN 5
Kasandrich
Bericht 1 van 6
6.155 Weergaven
Bericht 1 van 6
6.155 Weergaven
E15301 m.2 support
Hi all, i'm a newbie here
Just bought a Medion E15301 MD 62033
I saw it has an m.2 expansion slot on the underside, so I bought an m.2 ssd to expand the storage.
Ive plugged it in, but the laptop does not seem to power up with it  plugged in.
The M.2 ssd I bought is
WD BLACK SN750 NVMe SSD
Any suggestions would be appreciated.
Richard
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 4 van 6
6.135 Weergaven
Bericht 4 van 6
6.135 Weergaven
@Kasandrich
That's normal. SATA M2 SSDs  often have two keys, B + M Key. A PCIe NVME M2 SSD has a M -Key only. The question is which "Key" the slot provides. Because a M2 with two keys fits mechanically in each of tne slots, or with a B or with a M-Key only.
But the mechanical side is more or less unimportant, the fact which protokoll the slot provides is the dominating fact.
Usually the M Key is associated with the NVME protocol, while the B key is a SATA protocol.
Check with this M2 article in Wikipedia; especially look at the Chapter Formfactor and keying, and the very clear pictures there.
--> https://en.wikipedia.org/wiki/M.2
5 ANTWOORDEN 5
Kasandrich
Bericht 2 van 6
6.147 Weergaven
Bericht 2 van 6
6.147 Weergaven
Think Ive found the answer to my own question
inside the m.2 cover on the underside is a label "M.2 2280 SATA only"
So here I am with a very high performance WD Black NVMe 1tb M.2 SSD thats no use to me, I need a SATA one, my Son has recently built himself a gaming pc and bought 2 1TB m.2 SSD's but accidentally bought slower ones, so I need to get him to check the spec on his, if they are SATA I willl do a swap with him.
Kasandrich
Bericht 3 van 6
6.141 Weergaven
Bericht 3 van 6
6.141 Weergaven
My Sons m.2 drives are NVMe so no good to me.
Im really confused now because the SATA M.2 drives im looking at have 2 keyways.
my slot which says its SATA only only has the single keyway and the NVMe m.2 fits, so what do I need??
Bericht 4 van 6
6.136 Weergaven
Bericht 4 van 6
6.136 Weergaven
@Kasandrich
Kasandrich
Bericht 5 van 6
6.132 Weergaven
Bericht 5 van 6
6.132 Weergaven
I've now bought a sata 2tb and I'm going to replace the c drive with it.
Let's see how it goes
Bericht 6 van 6
6.123 Weergaven
Bericht 6 van 6
6.123 Weergaven
@Kasandrich
A   2 TB  M2  disk could be too big. As as far as I know a 256 GB or max, 500 GB M2 disk will fit.
5 ANTWOORDEN 5
