Compatible cpu and gpu fans for X7849
1 ANTWORT 1
DavidGaming669
Visitor
Nachricht 1 von 2
1.272 Aufrufe
Nachricht 1 von 2
1.272 Aufrufe
So, as the title suggests, I have an x7849 which is fairly aged and need a replacement for my cpu and may as well replace the gpu fan too, i do not have much money so buying fans that are £20-30+ each are not an option so I'm wandering which fans I could buy that are compatible.
Attached is a picture with the bottom removed, top left is cpu and the primary part that needs a replacement (if it will help cold it down) 0630a371-e3bf-4b2d-9d21-0627fe90afec.jpg
1 ANTWORT 1
Nachricht 2 von 2
1.257 Aufrufe
Nachricht 2 von 2
1.257 Aufrufe
Hello @DavidGaming669 and welcome
You have a barebones Clevo P670RS-G(M)
The entire cooling system is one unit and is no longer available.
You may be able to buy the fans separately since you've already thought about it:
https://www.x-comp.wien/laptop-ersatzteile/cooler/medion-cooler/dfs501105fr0tfhcx-5207.html
bye Fishtown
1 ANTWORT 1
