Can I disable the Caps Lock overlay?
2 ANTWORTEN 2
uint
Nachricht 1 von 3
1.878 Aufrufe
Nachricht 1 von 3
1.878 Aufrufe
I'm using Crawler E10. The overlay itself to me is useless since I have a external keyboard, and the overlay is annoying since using caps lock as a hotkey is already my habit. However I haven't found any options that allow me to remove the overlay.
The overlay:
2 ANTWORTEN 2
Nachricht 2 von 3
1.861 Aufrufe
Nachricht 2 von 3
1.861 Aufrufe
Hi @uint
Try the following: download the Logi program and install it:
https://www.computerbase.de/downloads/treiber/eingabegeraete/logi-options/
Open the program and go to “Settings” at the top right.
In the next screen (application settings) you scroll down and deactivate the button.
good luck, bye Fishtown
uint
Nachricht 3 von 3
1.832 Aufrufe
Nachricht 3 von 3
1.832 Aufrufe
Sadly this did not solve my problem. However when I killed the Control Center application the overlay disappeared. Thank you anyway!
@Fishtown wrote:
Hi @uint
2 ANTWORTEN 2
