Battery 255 %
21 ANTWORTEN 21
BGR
Nachricht 1 von 22
8.499 Aufrufe
Nachricht 1 von 22
8.499 Aufrufe
Battery 255 %
Laptop P6661 does not turn on with battery. The battery icon on taskbar shows  - 255 %available. Plugged in. If the charger is plugged off, the laptop shuts down immediately. Purchase a 2 new generic batteries - no success, The red light of battery on laptop panel is flashing when charger is connected.  Web wide ways to solve this issue was done. Nothing works. Somebody could help? Thanks in advance,
21 ANTWORTEN 21
Nachricht 11 von 22
3.598 Aufrufe
Nachricht 11 von 22
3.598 Aufrufe
@BGR
Maybe the power board only is the connecting board between power input socket and mainboard. And the intelligent circuit is on the mainboard itself. You should check before ordering the part.
Nachricht 12 von 22
3.582 Aufrufe
Nachricht 12 von 22
3.582 Aufrufe
@BGR
 For me in the synopsis the batteries you bought are "kaput"t- probably broken. Superimposed and deeply discharged in due to the long time without maintenance. The fact that there is still an open-circuit voltage of ~15 V says nothing about the voltage drop under load.
This is also what the behavior of the charging LED says.
Sorry, dadde
BGR
Nachricht 13 von 22
3.561 Aufrufe
Nachricht 13 von 22
3.561 Aufrufe
Have checked by multimeter new batteries voltage on the pins - did not found nothing. No any voltage. On the old one on some pins found 2-3 V.  Perhaps the "new" batteries are dead but I guess the problem is not on batteries only. Will research further. Now I need a really working battery for test.Thanks everybody for comments.
Nachricht 14 von 22
3.319 Aufrufe
Nachricht 14 von 22
3.319 Aufrufe
@BGR
Sorry to her, but thats what I did presume.
Did you manage in  the meantime to get the Laptop working?
Cheers, daddle
x
BGR
Nachricht 15 von 22
3.285 Aufrufe
Nachricht 15 von 22
3.285 Aufrufe
I disassembled both two new batteries, both have normal voltage 15,2 V, so I guess the problem is on motherboard power controller. Next step is put out the motherboard and looks for problem. Thanks.
Nachricht 16 von 22
3.274 Aufrufe
Nachricht 16 von 22
3.274 Aufrufe
@BGR
You wrote before:
And now:
If they do not give any voltage in assembled state out, like you wrote before, then it has nothing to do with the powerboard, because the batteries were not connected to the mainboard.
Disassembling and measuring the single cells having Voltage left, is not not proof enough. Check if the single cells under load (a few Ampere ) keeps the Voltage high.
BGR
Nachricht 17 von 22
3.263 Aufrufe
Nachricht 17 von 22
3.263 Aufrufe
I connected directly to battery a load (car halogen bulb, 55 W) and discharged a battery till 8 V. Bulb shined 25 minutes. Then installed battery to laptop and plugged in a charger ant check by multimeter charging voltage on cells - did not found any voltage. Results: the battery is not charging.
Nachricht 18 von 22
3.253 Aufrufe
Nachricht 18 von 22
3.253 Aufrufe
@BGR
You connected the 55 W bulb  directy to a single cell?  One after the other (they only  have about 3.2 V).
So you did  connect the bulb  to the outllet contacts of the assembled battery in total? Must have been.
But letting the bulb drain the battery down to 8 Volt  is deeply discharging  the single cells, which are getting damaged by less than 2.4 V.
Divide the 8 V by the amount of cells  (4 cells) , then you know how deeply discharged the single cell  is.
But mostly it doesn't affect the cells equally
A safety  circuit (BMS)) inside the batterie blocks the reloading, if the battery in total  (or some cells) is / are  deeply discharged.
One could try to give a direct higher voltage "shot",  with a bit higher voltage than the regular voltage of the charger offers,  to overcome the  blocking.
But this is risky, and you should be aware of the risks of fire which are there..
BGR
Nachricht 19 von 22
3.246 Aufrufe
Nachricht 19 von 22
3.246 Aufrufe
No no, I connect the bulb to full battery pack 15,2 V, after disconnecting the bulb battery voltage in 10 minutes rised up to 11 volts. So the cells are ok. I found on youtube some very similar issues fixing videos, where laptops batteries where does not charged, and problem was dead IC voltage controller chip.
Nachricht 20 von 22
3.244 Aufrufe
Nachricht 20 von 22
3.244 Aufrufe
@BGR
You change eveery time yur story. First yoiu wrote :
 Now you say:
This  is very on the borderline.  Now i cannnot  help any more.
dadlle
21 ANTWORTEN 21
