Akoya E16433 Fan to loud
1 REPLY 1
Ifreakis
Message 1 of 2
Message 1 of 2
Hi i just bought a medion Akoya E16433 but i have a little problem with the fans. The laptop sit in idle at a tempo around 40 C, when i launch a single problem whatever it is, the temp jump over this 40 C and the fans start to be extremly loud. (There is a way to change this behavior, controlling the fans?)
Hope u can help.
1 REPLY 1
Igor28
Message 2 of 2
Message 2 of 2
Hi @Ifreakis ,
1. Update BIOS/Firmware
  • Check the Medion website for the latest BIOS or firmware updates for your model.
2. Adjust Power Settings
  • Go to Control Panel > Power Options in Windows and set the power plan to “Balanced” rather than "High Performance."
  • In the advanced power settings, you can also modify the CPU power settings to reduce the amount of heat generated. Look for options like Processor power management and lower the maximum processor state to prevent the CPU from running at full power all the time.
3. Check Task Manager for Background Processes
Ensure that there are no unnecessary background processes or programs consuming CPU power and generating heat. Sometimes, even light tasks like running multiple tabs in a browser or having many background applications can cause temperature spikes.
1 REPLY 1
