Memory Medion Akoya P4130
1 ANTWORT 1
Limbo210366
Nachricht 1 von 2
1.252 Aufrufe
Nachricht 1 von 2
1.252 Aufrufe
Hello,
First I had 2x 4GB RAM inside the desktop.
I bought 2x 8GB DDR3 RAM, installed it and now the computer won't start up anymore.
When I place the old sims, it does work.
Can someone please tell me which exact DDR3 sims I should buy to get 16GB RAM, so I won't buy the wrong sims (I think) again. Maybe with a link to a store?
Thanks a lot and best regards, Jurgen
1 ANTWORT 1
Nachricht 2 von 2
1.244 Aufrufe
Nachricht 2 von 2
1.244 Aufrufe
Hi @Limbo210366 and welcome
Information about the installed RAM: 2x 4096 MB DDR3L-SDRAM (PC3-12800 / 1600 MHz) Dual Channel Memory (2/2 Slots covered; 16 GB max.)
Memory Support
  • DDRIII 1600 / 1866 / 2133 MHz (16 GB Max)
  • 2 DDRIII DIMMs (240pin / 1.5V)
  • Single / Dual channel mode
bye Fishtown
1 ANTWORT 1
