W11 compatibility
1 ANTWORT 1
cuchulain
Nachricht 1 von 2
2.604 Aufrufe
Nachricht 1 von 2
2.604 Aufrufe
W11 compatibility
I have a PC W11 intel core i7 2600 cpu 3.40 ghz and according to Microsoft it does not allow me to update to W11. There is some possibility of software or hardware to carry out the update.
Thanks
1 ANTWORT 1
Mastermind
Nachricht 2 von 2
2.565 Aufrufe
Nachricht 2 von 2
2.565 Aufrufe
Hi @cuchulain ,
to give you a helping answer, you´ll have to specify your PC a bit more. When did you buy it at which distributor, which mainboard is built in an maybe you also have the 8-digit (1001xxx or 1002xxx) MSN number in hand, which is printed on the lower side of the PC?
Cheers
1 ANTWORT 1
