46154members
1020online
158119posts
A patch is a set of changes to a computer program or its supporting data designed to update, fix, or improve it. This includes fixing security vulnerabilities[1] and other bugs, with such patches usually being called bugfixes or bug fixes, and improving the usability or performance. Although meant to fix problems, poorly designed patches can sometimes introduce new problems. In some special cases updates may knowingly break the functionality, for instance, by removing components for which the update provider is no longer licensed or disabling a device.
