22.12.2024 11:10 - edited 22.12.2024 18:16
Hi everyone, I bought a new notebook medion erazer major x20 md 62520 (MSN30035496) and I'm encountering two problems: 1- the battery not charging specifically, the battery is always at 0% and as soon as I connect the charger the red LED flashes for a few minutes, then remains solid red for a few more minutes and then turns off. The charger works correctly because I tried with a voltmeter and 19.9v comes out as expected
2- there are problems with the in-game wattage of the RTX 4070 video card which does not go beyond 30W of power causing low fps. I checked that the various driver and Windows settings were set correctly or even set "maximum performance" but nothing changed.Another strange thing is that the GPU clock in the menu is correct while in game it drops, and vice versa the percentage of clock usage. Could it be bios related? (i'm on bios 1.07med02 and ec 0.30). I saw a post with a similar problem and it was solved with a bios and ec update https://community.medion.com/t5/ERAZER-Gaming/Erazer-Major-X20-MD62525-NEED-LATEST-BIOS-UPDATE/td-p/...
Can i eventually update bios to gmxpx7xn109med06 and ec GMxPXxx_11.600?
The battery problem doesn't bother me by always using it connected to the AC but I would like to solve the gpu wattage problem as long as it is not related to the battery problem which perhaps does not receive enough voltage to recharge and make the whole thing work properly.
Thanks in advance!
23.12.2024 22:07
23.12.2024 22:07
After fiddling with programs and settings for days I managed to come to the conclusion: in practice it seems that the video card is in sleep mode when the system starts and needs to be woken up. I found the solution by enabling the developer options on the nvidia control panel and selecting one of the two items present under gpu counters. By doing so the card refreshes and unlocks full power.
I have all the windows and nvidia settings set to maximum performance so I don't know which of the two has a bug or if it is a problem related to the fact that the battery is not working and is at 0% constant and puts the pc in a sort of energy saving. If anyone has any ideas on what it could be and how to avoid doing this procedure at every start I thank you. In the meantime I am thinking about whether to have the pc replaced for the non-working battery.... Is it possible to have medion send a battery under warranty without having to return the pc to the supplier and have them give me a new one or have it sent in for repair?
24.12.2024 07:36
24.12.2024 07:36
Hi @ago89 and welcome to the Community,
first of all thank you for your detailed issue report and (of course) we´re thankfull for your present investigations, that helped to solve one of the "issues".
My thoughts on that: Did you already "play" with the settings of the ERAZER Control Center application and maybe try to switch the Power Profile"?
Regarding the battery problems we´ll send you a Private message in brief, to help you solving this issue.
Ciao
24.12.2024 08:52 - edited 24.12.2024 09:02
Hello @Major_ToM and thanks for the welcome and the answer. Believe me, in two days I tried everything even uninstalling the erazer control center to see if it created a conflict with something else, fiddling with entries in the bios, changing windows power plan also enabling hidden features,trying different nvidia drivers,ecc but there was no way to get the gpu to go into operation.
it doesn't let me send pm. it gives me this error:
You have reached the limit for number of private messages that you can send for now. Please try again later.
24.12.2024 09:36
24.12.2024 09:36
Hi @ago89 ,
well.. I absolutely belive you, but would appreciate to get further feedback from other Community users, which own the ERAZER Major X20.
Could you please LogOff/LogIn once and then try to answer my message?
Maybe this helps
