erazer defender p15 bios
14 REPLIES 14
aaamedion
Message 1 of 15
Message 1 of 15
where can i find  erazer defender p15 (md 62243) msn 30033568  bios file?
mb series NHxOERQ.EPY
bios version : 1.07.01RME_00004
or newest bios , please help me
14 REPLIES 14
gfischer
Message 11 of 15
Message 11 of 15
@Major_ToM Thanks for your reply, but you are referring to @aaamedion to perhaps have solved the issue. But that is not what I want to wait for, since I believe it is a BIOS issue.
@Andi is there a way to revert to the previous BIOS Version , because this version is causing my Nvidia card to be not detected? I have the same issue as user aaamedion, where it shows N/A in the BIOS. I really need your help to fix this issue as I cannot use my graphics card now.
kind regards, GFischer
aaamedion
Message 12 of 15
Message 12 of 15
hi
@gfischer@Major_ToM
, I cant ran the nvidia, and I came back earlier bios,
I found the earlier bios, in clevo web site. Is stable working but lid open feature is not working (I open the lid, the laptop not switches on). otherwise is no problem .
I have some heating issues, but I'm not sure if it's related to the bios version I'm using. Maybe it's related to the charging port. I changed the charging port because of the heating issue I was experiencing. If you want, I can try to find the bios link on the clevo website. If I find the link, I will try to add it. It is up to you to use it or not.
aaamedion
Message 13 of 15
Message 13 of 15
Tags (1)
gfischer
Message 14 of 15
Message 14 of 15
@aaamedion That link you provided helped me to get the correct BIOS. I am very grateful. The laptop now works as it should and I do not have issues with the lid. I am using the last version 1.07.09 . Thank you!
@Major_ToM  and @Andi The version you have provided 1.07.05 is not provided anymore in the CLEVO link (other versions are present). So please remove it from the forum as it causes videocard disabled problems. I also find it very strange that for help we need to rely on the community and the fix does not come from Medion support. I am very disappointed about that.
Message 15 of 15
Message 15 of 15
Hi @gfischer ,
thanks for your answer. As requested I firstly removed the download-link in post #5 and secondy launched a request to our tech dept.to receive an appropriate bios version for your laptop.
Will respons asap
Cheers
14 REPLIES 14
