X30 beast shutting itself off?
4 REPLIES 4
Bethp1
Message 1 of 5
Message 1 of 5
Received my medion x30 beast today. While booting a game without power cable in, it shuts it self off and doesn't come back on for a while.
It isn't hot to touch.
Could this be a technical problem or lack of power to the cpu and gpu causing a power surge to protect itself?
Tags (1)
4 REPLIES 4
EastClintwood
Message 2 of 5
Message 2 of 5
Hi @Bethp1, and welcome to the community.
If the problem has only occurred once, then I would rather assume a software problem and not a hardware defect.
It would be good if you could give us your MSN number (3003XXXX), if the problem has already occurred several times,  so we can try to reproduce the problem.
Greetings,
EastClintwood
Bethp1
Message 3 of 5
Message 3 of 5
Hey @EastClintwood ,
It has happened 3 times so now play with power in but means I won't beable to play away from power source thanks
MSN number is : 30033995
EastClintwood
Message 4 of 5
Message 4 of 5
Hi @Bethp1
Thank you for your quick reply.
I have forwarded your problem to the relevant department and as soon as they have investigated your case and come to a conclusion, I will get back to you.
Regards,
EastClintwood
Sandro6880
Message 5 of 5
Message 5 of 5
Greetings, just wanted to ask if the problem was already found? Had it happen a couple of times and it seriously doesn't want to turn on for at least 10 minutes.
The problems have also only been happening since I started using the stationary mode for power supply, can't recall that there were incidents like this before that. So is there some kind of problem with that? If the power cable isn't plugged in while you try to use the laptop on that setting?
4 REPLIES 4
