Upgrade to Windows 11 on ERAZER X7847
1 REPLY 1
FGS
Message 1 of 2
Message 1 of 2
Hi,
I have a gaming laptop ERAZER X7847, and I would like to upgrade it to Windows 11, but when I try to launch the installer, I receive a message about the processor is not compatible with Windows 11 (i7-6820H). So, my question is Why this processor is not compatible with Windows 11? Are there any procedure to upgrade my PC to Windows 11?
Thank you very much in advance for your support, and best regards.
Fernando.
1 REPLY 1
RAZZ
Message 2 of 2
Message 2 of 2
Hello @FGS
certain processors are not compatible with Windows 11 you can verify if your unit is compatible with Microsoft from the links below
https://www.microsoft.com/en-gb/windows/windows-11-specifications?r=1
https://support.microsoft.com/en-gb/windows/how-to-check-if-your-device-meets-windows-11-system-requ...
Thanks
1 REPLY 1
