Upgrade p6681 storage to an M.2 NVME drive
3 REPLIES 3
harrystacey
Message 1 of 4
Message 1 of 4
Hello, I'm currently on a 1tb Hard Drive with my medion erazer p6681 (MSN: 30022543). I wanted to upgrade to an M.2 nvme to use as a boot dive to speed it up, however I'm not sure which format of m.2 drive to buy.
Does the laptops motherboard support a key of "B + M", "M" on its own or just "B" on its own?
Length wise, is it a 2280 drive that it would support or shorter?
And finally, whats the max storage amount that I could install with the m.2 drive?
If someone could help me out with this, that would be amazing!
Cheers, Harry
1 ACCEPTED SOLUTION
Message 4 of 4
Message 4 of 4
Hi @harrystacey
officially up to 512GB, so it comes from this post:
https://community.medion.com/t5/ERAZER-Gaming/Gr%C3%B6%C3%9Fere-SSD-1-TB-in-Erazer-P6681-MD-60608-ei...
you can try 1TB, it`s your risk
bye
3 REPLIES 3
Message 2 of 4
Message 2 of 4
Hello @harrystacey and welcome,
there is another p6681 MSN30025237, https://media.medion.com/prod/medion/de_DE/0743/0836/0675/30025237.pdf
with 1TB HDD and an SSD.
SSD M.2 (2280) 256GB SK Hynix HFS256G39TND-N210A, this is a SATA not a nvme
The board is the same: Pegatron E15KR.
bye Fishtown
harrystacey
Message 3 of 4
Message 3 of 4
So would this be fine seeing as its an M.2 2280 sata drive?
https://www.amazon.co.uk/Samsung-Sata-Solid-State-Drive/dp/B078WQT6SB/ref=sr_1_4?dchild=1&keywords=m...
Samsung 860 EVO 1 TB SATA M.2 (2280) Internal Solid State Drive (SSD) (MZ-N6E1T0)
Message 4 of 4
Message 4 of 4
Hi @harrystacey
bye
3 REPLIES 3
