Upgrade P15805
6 REPLIES 6
ianc153
Message 1 of 7
Message 1 of 7
Upgrade P15805
Hi,
Bit of a noob to Medion pc's.
Just recently bought an erazer p15805 and would like to add an additional hard drive. Is there a service manual available to get inside the case? Also is this something that would invalidate the warranty?
cheers
Ian
2 ACCEPTED SOLUTIONS
Gehringer
Retired
Message 2 of 7
Message 2 of 7
Hi @ianc153 ,
adding an HDD to your model should not be complicated to someone who has some hardware maintenance knowledge, particularly on installing HDDs into SATA III connectors,  but Medion can't recommend you to do it if you don't know how to do so.
If Medion technicians identify any evidence that a repair/upgrade was not performed with a professional quality level (burns/marks/scratches/damages etc) the warranty is voided.
Regards,
Gehringer
ianc153
Message 6 of 7
Message 6 of 7
Hi
Hope this is ok?
Found this message thread on the German language message board
https://community.medion.com/t5/ERAZER-Gaming/Medion-Erazer-P15805-zus%C3%A4tzliche-SSD-aufr%C3%BCst...
Details everything necessary to open the case and add extra drives.
Ianc
6 REPLIES 6
Gehringer
Retired
Message 2 of 7
Message 2 of 7
Hi @ianc153 ,
Regards,
Gehringer
ianc153
Message 3 of 7
Message 3 of 7
Hi @Gehringer
thanks for the warranty info.  I’m knowledgeable enough to put in hdd’s, I’ve had my dell laptop apart to change hdd and add memory, it’s not difficult with the correct info to dismantle the case! Is there a document to show how the case comes apart?
Gehringer
Retired
Message 4 of 7
Message 4 of 7
Hi @ianc153 ,
I am sorry, but unfortunately not.
Regards,
Gehringer
ianc153
Message 5 of 7
Message 5 of 7
Hmmm that’s a shame, looks like I won’t be taking it apart any time soon
ianc153
Message 6 of 7
Message 6 of 7
Hi
Hope this is ok?
Ianc
ianc153
Message 7 of 7
Message 7 of 7
Done it, really easy to do, German message thread helped loads
6 REPLIES 6
