Regarding the Full Color “Per Key” LED Keyboard
5 REPLIES 5
cabanesnacho
Message 1 of 6
Message 1 of 6
I have recently acquired a Medion Scout E30i. I can't seem to access the Full Color “Per Key” LED Keyboard in the Control Center, to customize the lighting under each key. According to the manual, I should be looking at something like this
But instead, the menu looks like this
Which is the Multi-Color LED Keyboard, that only allows to change the key lights in tandem.
Is there any way to get access to the Full Color “Per Key” LED Keyboard in the Control Center, so that I can customize the color for every key? Or is it not possible in my PC?
1 ACCEPTED SOLUTION
Message 4 of 6
Message 4 of 6
Hello @cabanesnacho ,
only the setting like in the second picture (CC) works, you can only change the color of the entire buttons. There are 15 different colors to choose from.
It is not possible to assign different colors to individual keys.
bye Fishtown
5 REPLIES 5
Message 2 of 6
Message 2 of 6
Hi @cabanesnacho and welcome
bye Fishtown
cabanesnacho
Message 3 of 6
Message 3 of 6
Sorry, I don't understand what you mean.
Message 4 of 6
Message 4 of 6
bye Fishtown
cabanesnacho
Message 5 of 6
Message 5 of 6
Thank you. I don't understand why the other option appears in the manual, then.
Message 6 of 6
Message 6 of 6
as you wrote yourself, these are options.
This is not stated in the Medion operating instructions.
You are certainly talking about the manual from the manufacturer Clevo itself. Now all the variants with which you can get the model are listed there. Similar to the service book for the automobile, all versions available are listed there.
bye Fishtown
5 REPLIES 5
