28.05.2025 23:05
28.05.2025 23:05
I have a Medion Erazer Recon P20 (msn 10024815) running version BIOS Version B660H7W0X.107 (Release Date 23/02/2022) on a B660H7-M20 motherboard.
My question is surrounding two things. First is if there is a way to enable XMP Profile on this motherboard with a BIOS update or such, as I had bought 32gb 3200 mhz ram, but because it is not currently available in BIOS, it defaults to 2133 mhz. Is there any solutions, or is it pure BIOS/Motherboard limitation?
Also, I am currently trying to install a PCIE wifi adapter (tp-link tx3000e), however my system is in no way picking it up, even though i have the wifi drivers, and I installed the wifi card in the correct slot, unless i am wrong. I attached an image of the motherboard with the slot i am talking about.
I will appreciate any help in this matter.
29.05.2025 15:18 - edited 29.05.2025 15:19
Hello,
you can't RAM with XMP and 1,35V. Only RAM 3200MHz with 1,2V!
Newer BIOS v1.112 for your Mainboard
Hello, you can Bios Update only Version V1 .112 (not install with inf file)! Not V2 .212, is'nt kompatibel!
https://cdn.medion.com/downloads/software/00_Bios_b660h7-m20.zip
Hello,
29.05.2025 15:34
29.05.2025 15:34
Your Mainboard have M.2 Slot for WiFi/BT. You can install your WiFi-Modul from your Card.
Here Manual for your motherboard
https://www.ecs.com.tw/de/Product/Motherboard/B660H7-M20/download
