P6689 USB C Display possible?
1 RÉPONSE 1
tensor
Message 1 sur 2
1 513 Visites
Message 1 sur 2
1 513 Visites
Hi
I have been trying to set up to use two monitors with my P6689 by using a USB-C adapter, however it is not working. I have tried both HDMI & Displayport cables with no luck - i get a message "Display connection might be limited".
I have tried reading around this subject and discovered that not all USB-C is the same. but I can not find anything that tells me what the P6689 will or will not support. Is there any way of achieving this?
Thanks
1 RÉPONSE 1
sweetpoison
Message 2 sur 2
1 509 Visites
Message 2 sur 2
1 509 Visites
Hi @tensor , welcome to the forum
No idea if USB C in your laptop can be used for video output. Although I found this https://www.delock.com/produkt/87755/merkmale.html
And for a safe bet: https://www.delock.com/produkt/87691/merkmale.html
Anyway, for either of them, try to find a merchant which accept refund in case is not what you were looking for.
Cheers
1 RÉPONSE 1
