Open a x7859 to change the HDD
5 REPLIES 5
Xavier-CH
Message 1 of 6
Message 1 of 6
Hello,
The HDD in my laptop died after about 4 months of use. I got some cyclic redundancy problems (on Windows, input/output error in Ubuntu) that are caused by a hardware problem and have to change it.
The Swiss provider of my laptop is taking too much time to answer about my problem and as I'm in Thailand anyway undertaking a Master Degree online I need my laptop on a day-to-day basis to work. I thus ordered a new one and want to change it myself (I'm a software engineer with experience in pc assembly).
I tried this morning, I unscrewed the 12 screws from behind the computer and 1 hidden under a black rubber wrap. Despite this there must still have been 1 or 2 screws remaining that prevented me to open the laptop to change the disk but I couldn't find them.I also couldn't find anything relevant in the manual or this forum (or even Google).
So I'm writing you here to ask you this : Could you please tell me where are the remaining screws I have to take off to open my laptop? Are they under the keyboard that I should also take off?
Thanks in advance for your answer,
Kind regards,
Xavier
PS: MSN is 30025637, laptop bought by Digitec.ch order n°22285428, opened ticket at Digitec n° 4381278
Tags (3)
1 ACCEPTED SOLUTION
Message 4 of 6
Message 4 of 6
Hi @Xavier-CH
you want to open the laptop, then look here:
http://s472165864.onlinehome.fr/anyware/manuels/PA70HP6.pdf
your assumption with the screw under the keyboard is correct.
bye Fishtown
5 REPLIES 5
Xavier-CH
Message 2 of 6
Message 2 of 6
I also would like to inquire about the warranty. As my HDD died a few months after I bought it it should have been covered by the warranty. My Swiss provider just answered me and advised me to check with you directly for any kind of repair/refund.
Now I just bought a Seagate barracuda, the same model as the one in the laptop itself on Lazada. Would there be a way to get reimbursed for this HDD? Or will you send me another one? How would you advise me to proceed here?
Kind regards,
Xavier
TPFLegionaire
Retired
Message 3 of 6
Message 3 of 6
Hi @Xavier-CH
welcome to the forum, sorry we overlooked your post.
whilst I hope you have found all the screw by now , I attach schematic of the back of the machine with the screws emplacement circled in red.
the link to the manual is here just in case you need it:
http://www1.medion.de/downloads/download.pl?lang=uk&filename=bda_x7858_x7857_x7856_x7855_en.pdf&id=1...
As far as the warranty for the HDD is concerned, we can't do anything to/from Thailand, we would need to pick it up from a Swiss/EU address.
You can of course make a claim within the time limit of the warranty once you are back in the right Geography.
I hope I have covered both issues, Let me know if you need anything else.
In the meantime, I wish you best of success with your PHD.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Message 4 of 6
Message 4 of 6
Hi @Xavier-CH
bye Fishtown
Xavier-CH
Message 5 of 6
Message 5 of 6
Hey Fishtown,
Thanks that's exactly what I needed! I managed to do it yesterday and it went flawlessly. I also noticed I have a free space for some more RAM, I'll add some later.
@TPFLegionaire : With all due respect did you even read my post? As I wrote in my first post I already read the manual and took off every screw from the back but it was the one hiding under the keyboard was blocking me. And I'm not doing a PhD but a Master's degree.
TPFLegionaire
Retired
Message 6 of 6
Message 6 of 6
@Xavier-CH
Doh! looks like I completely missed the mark!
Thankfully we are a community that helps and support each other, so I am glad that @Fishtown had my back and was able to give you the answer you needed.
Wish you the best of success with your master degree.
Cheers!
TPFLegionaire
5 REPLIES 5
