New Bios for Medion Erazer P30
6 REPLIES 6
AndyBiker
Message 1 of 7
Message 1 of 7
Hi,
I have an Erazer Deputy P30 notebook.
msn: 30034316
My "old" Bios:
vendor INSYDE Corp.
version 1.07.02RME1_022
Do you know if an updated bios is available?
Where can I find Bios for this Notebook?
Thank you.
6 REPLIES 6
Mastermind
Message 2 of 7
Message 2 of 7
Hi @AndyBiker
generally updates are provided by the Windows update functionality of your system (do not forget to even hunt for optinal updates), but I also can provide the Bios version 1.07.04RME1 available here (suits to the line ERAZER Deputy P30 & Specialist P10)
The thing with the update is, that i have no logfile in hand, which means, that I can´t tell you about the modifications and as we all know updating a successfully running system might lead to "strange behaviour", so you have to be aware, that for any errors, which are caused by the execution of this update, MEDION campany doesn´ t accept any responsibility for damage or lost of data.
You agree with that fact by executing the update.
Cheers
jimwin
Message 3 of 7
Message 3 of 7
is the link given earlier still the latest BIOS for Erazer Deputy P30?
I have just purchased one, and it's still on 1.07.02RME1_010
I'm confused to how I can get BIOS updates through windows update.  The system firmware device is showing as a generic "system firmware" device in device manager, with manufacturer being Microsoft.
How can I get my firmware updated?
Thanks!
Mastermind
Message 4 of 7
Message 4 of 7
Hi @jimwin ,
could you please inform us, if your issue with your ERAZER Deputy P30 laptop is still present?
Despite using the general Windows Update utils you could aldo add the search for optional updates.
Cheers
jimwin
Message 5 of 7
Message 5 of 7
hi Major ToM,
yes, the issue is still present.  In Device Manager I can see the "Medion Deputy P30" device under "Computer", but I only see "Device Firmware" and "System Firmware" under "Firmware".  All of these are showing as Microsoft drivers with dates from 2006.
I've not seen any firmware updates since I manually installed the version you posted before.
Thanks for your help!
AndyBiker
Message 6 of 7
Message 6 of 7
Some problem for me.
Are we sure that Medion publishes the bios on Microsoft update?
At this point I think it's Medion that doesn't release updates. Besides the Bios mentioned here I was unable to find any other updates.....
Mastermind
Message 7 of 7
Message 7 of 7
HI @AndyBiker & @jimwin ,
I checked with the tech team, an can offer V 1.07.04RME, if this is suitable for you?
Remind, that for any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.
Cheers
6 REPLIES 6
