Motherboard replacement Medion Erazer Guardian X10 MD61980
1 REPLY 1
Hulk207
Message 1 of 2
Message 1 of 2
Hello,
I have a laptop Medion Erazer Guardian X10 MD61980 (MSN: 30030052) in which a small part of the motherboard has burned out, probably due to a power surge or short-circuit, and the laptop is unusable. I want to replace it if possible. The warranty is no longer available.
https://www.medion.com/medionserviceshop/fr/p/boitier-nb-erazer-guardian-x10-md61980-be-30030052
Among the product's spare parts, I can't find the "Motherboard" component. Does the "Powerboard" component (MSN: 40076252), at around $25, represent the motherboard ?
https://www.medion.com/medionserviceshop/fr/p/div-boards-powerboard-40076252
If not, is a motherboard found on Ebay, at around $200, called Laptop Motherboard GM5MPHY MB V1.0 SRH8Q i7-10750H RTX 2060 N18E-G1-B-KB-A1 compatible with my laptop
N.B.: I have the impression that the CPU and GPU are soldered to the motherboard. In the one I found on Ebay, the CPU is the same but the GPU is different from my laptop (RTX 2070 Super).
Thank you for your help and answers.
Kind regards.
1 ACCEPTED SOLUTION
RAZZ
Message 2 of 2
Message 2 of 2
hi @Hulk207
the correct mainboard for this unit is
40075410NBC MB I7‑10750H TF GM7MPHP
you can search on 3rd party websites for availability if it is not on the official Medion site.
The power board is not the MB it manages and distributes electrical power to the laptop.
unit specs -
thanks
1 REPLY 1
RAZZ
Message 2 of 2
Message 2 of 2
hi @Hulk207
unit specs -
thanks
1 REPLY 1
