Medion Erazer x7825 bios/EC
13 REPLIES 13
Magnusson2004
Message 1 of 14
Message 1 of 14
Hi
I have bought a second hand Medion Erazer x7825. There is no MSN number to be found.
I am looking for a new bios and EC, as the one I have is from 2013...Is there a newer bios and EC?
Plus, I wanted to upgrade from a gtx 770m to a newer card...a gtx 980m. Would this be possible without too much hassle?
1. Is it plug and play?
2. Would my existing heatsinks from 770m work with the 980m?
Thanks in advance
/Michael
Tags (4)
1 ACCEPTED SOLUTION
Magnusson2004
Message 11 of 14
Message 11 of 14
Figured something else out..no need for assistance.
BR
Michael
13 REPLIES 13
TPFLegionaire
Retired
Message 2 of 14
Message 2 of 14
hi @Magnusson2004
if you look in windows---system information, the last 8 digit of your system SKU will give you the MSN number of the machine
once that is identified you can take a look at our service site for drivers and manual.
you can also try running the diagnostic app .
https://www.medion.com/gb/service/
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Magnusson2004
Message 3 of 14
Message 3 of 14
Hi
Thanks for your help.
I will try that today.
I was looking at the available bios before, how does it work..do I just start up AFUDOS/AFUWIN or would I need to move the flash files to a usb?
Or is there a flash program for them?
Kind regards
Michael
Magnusson2004
Message 4 of 14
Message 4 of 14
Hi again,
There is no system SKU ...it only says "To be filled by OEM".
Any other way to identify it?
Kind regards
Michael
Gehringer
Retired
Message 5 of 14
Message 5 of 14
Hi @Magnusson2004 ,
have you bought it in the UK?
If so, please try looking for the MSN 30015833 at our website and check if it is the same NB that you have.
Regards,
Gehringer
Magnusson2004
Message 6 of 14
Message 6 of 14
Hi @Gehringer
No, it is bought in Denmark.
Is it still possible to look at that MSN number then?
All the best
Michael
Gehringer
Retired
Message 7 of 14
Message 7 of 14
Hi @Magnusson2004 ,
try this one then 30015835.
Regards,
Gehringer
Magnusson2004
Message 8 of 14
Message 8 of 14
Hi @Gehringer
According to the specifications, that looks correct.
So I download and unzip the bios/ec..how do I start the flashing itself? Click on the AFUDOS program or?
Kind regards
Michael
TPFLegionaire
Retired
Message 9 of 14
Message 9 of 14
Hi @Magnusson2004
I would strongly recommend we confirm the MSN before going to a bios update. could you post a screenshot of your "system information" after  you boot into windows.
Cheers!
TPFLegionaire
Magnusson2004
Message 10 of 14
Message 10 of 14
Hi @TPFLegionaire
Here is my system info...had to copy-paste it: (it is in Danish though)
OS-navn Microsoft Windows 10 Home
Version 10.0.18363 Build 18363
Anden OS-beskrivelse Ikke tilgængelig
OS-producent Microsoft Corporation
Systemnavn DESKTOP-B7L4T0J
Systemproducent MEDION
Systemmodel X782X
Systemtype x64-based PC
System-SKU To be filled by O.E.M.
Processor Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz, 2401 Mhz, 4 Kerne(r), 8 Logisk(e) processor(er)
BIOS-version/dato American Megatrends Inc. E1763IM7.508, 07-06-2013
SMBIOS-version 2.7
Version af integreret controller 255.255
BIOS-tilstand UEFI
Motherboard-producent MEDION
Motherboard-produkt X782X
Motherboard-version To be filled by O.E.M.
Platformrolle Mobiltelefon
Sikker bootstarttilstand Slået til
PCR7-konfiguration Binding er ikke mulig
Windows-mappe C:\Windows
System-mappe C:\Windows\system32
Startenhed \Device\HarddiskVolume4
Landestandard Danmark
Abstraktionslag for hardware Version = "10.0.18362.752"
Brugernavn DESKTOP-B7L4T0J
Tidszone Rom, sommertid
Installeret fysisk hukommelse (RAM) 16,0 GB
Fysisk hukommelse i alt 15,9 GB
Tilgængelig fysisk hukommelse 10,3 GB
Virtuel hukommelse i alt 18,8 GB
Tilgængelig virtuel hukommelse 11,4 GB
Plads til sidefil 2,88 GB
Sidefil C:\pagefile.sys
Kerne-DMA-beskyttelse Slået fra
Sikkerhed baseret på virtualisering Ikke aktiveret
Understøttelse af enhedskryptering Årsager til mislykket automatisk enhedskryptering: TPM er ikke brugbar, PCR7-binding understøttes ikke, Test af hardwaresikkerhedens grænseflade mislykkedes, og enheden er ikke moderne standby, Der er registreret DMA-kompatibel bus/enheder, som ikke er tilladt, TPM er ikke brugbar
Hyper-V - VM-udvidelser af overvågningstilstand Ja
Hyper-V - Udvidelser af adresseoversættelse på andet niveau Ja
Hyper-V - Virtualiseringsaktiveret i firmware Ja
Hyper-V - Forhindring af datakørsel Ja
Hope this helps?
BR
Michael
13 REPLIES 13
