Medion Erazer X7843 MD99945 - Keyboard
3 REPLIES 3
Xenomorph
Message 1 of 4
Message 1 of 4
Good Morning.
I have a Medion Erazer X7843(MD99945) and wanted know whether and how I can change the back colour of the keyboard?
Regards
Wayne
Tags (2)
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @Xenomorph and welcome to the forum!
Can you please confirm that your NB MSN is 30020518?
If so, have you tried using the control center?
It can be downloaded from here if you don't have it on your PC.
Regards,
Gehringer
Xenomorph
Message 3 of 4
Message 3 of 4
Hi
Thanks for the reply and yes I have tried the control centre but there is no option to change the led colour.
My model is;
System Model Erazer X7843 MD99945
System Type x64-based PC
System SKU ML-210009 30020518
I don't know whether I am downloading the wrong software or maybe this laptop doesn't have that facility?
Thanks
Wayne
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @Xenomorph ,
your user guide mentions two settings available for the keyboard lights:
Fn + F2 - Background lighting options: Turns off background lighting for the integrated display to save power. The lighting is turned back on by pressing any key.
FN + F4 - Keyboard lighting options: 5 different brightness levels available.
If the Control Center that I have linked on my last reply does not offer you the light colours changing function I am afraid your NB does not have it.
Regards,
Gehringer
3 REPLIES 3
