Medion Erazer X10 CPU and BIOS issue
1 ANTWOORD 1
Shak354
Bericht 1 van 2
893 Weergaven
Bericht 1 van 2
893 Weergaven
Hello I bought my pc through Medion, I have :
I5 12400
Rtx 3060ti
Windows 11
gigabyte b660m ds3h ax ddr4
PKG Power 47w on cinebech
Cinebench multi core 4888 score.
My cpu isn’t ruining at full capacity despite me getting 3999mhz reading.
My Bios version is 100
It doesn’t allow me to update the bios manually.
Any help guys?
1 ANTWOORD 1
JacobP
Bericht 2 van 2
731 Weergaven
Bericht 2 van 2
731 Weergaven
Hello there @Shak354 ,
Its very uncommon for a CPU to ever max out. There is no need for it to be using all of its cores at the same time which is why it will display that only a percentage is being used.
If you are looking for an updated BIOS I recommend contacting Medion directly.
1 ANTWOORD 1
