Medion Erazer P15603 Ram Upgarde Spec
2 REPLIES 2
Browny1991
Message 1 of 3
Message 1 of 3
Hi All,
Have A P15603 Come With 8gb Of Ram And A Free Slot So Ordered Another 8gb And Have Been Running It With The 16gb 2x8gb But From Looking My Model Can Support 32gb So 2x16gb But Can't Find Which 16gb Ram It Will Accept Or A Spec For Them Anywhere Hoping Some One Can Help Here Laptop Details Below.
MSN 30027149
P15603-MD61591
Come With Samsung 8gb Ram 1rx8 pc4-2666v-sa1-11
Running Windows 10
Tags (1)
2 REPLIES 2
Dannyrozza94
Message 2 of 3
Message 2 of 3
Hi Browny,
I'm having the same thought as to upgrading the ram in my P15603. Was wondering what 8gb you bought/what is inside the laptop from the factory.
Cheers
Dan
Message 3 of 3
Message 3 of 3
@Dannyrozza94
Hi, built in is
1x 8 GB DDR4 SO-DIMM (PC4-21300/ 2666 MHz)
(1/2 Slots covered; 32GB max.)
There are two slots,each, one covers 16 GB max
@Browny1991  wrote it came with a Samsung ram - bar  "Come With Samsung 8gb Ram 1rx8 pc4-2666v-sa1-11"
So you have all the specs.
You could order a second 8 GB ram from Samsung hoping it will do Dual Channel
Or you buy a pair of two other 8 GB ram bars, then dual-channel should work definitely.
Or twice a 16 GB ram bar, but what fore ? It's quite expensive, and of no use except you do a lot of video-cutting.
by, daddle
2 REPLIES 2
