Medion Erazer Defender P10 MD62255
6 REPLIES 6
sixsonic
Message 1 of 7
Message 1 of 7
Hello,
Im looking into the MD62255, a medion laptop with an i7-10750H and a 3060.
Im wondering what TGP this laptop GPU has, can anyone tell me this?
Thanks !
Tags (1)
1 ACCEPTED SOLUTION
sixsonic
Message 7 of 7
Message 7 of 7
I have bought the laptop, it has a average of 105w, it spiked to 111w a few times.
So i assume it has 115w TGP.
Happy with the purchase!
6 REPLIES 6
sweetpoison
Message 2 of 7
Message 2 of 7
Hunting for an answer requires a proper question. So what is "TGP"?
And welcome to the forum @sixsonic
sixsonic
Message 3 of 7
Message 3 of 7
@sweetpoison
TGP stands for Total Graphics Power
Ive seen models of other manufacturers with 80w+20w dynamic boost, so 100w TGP .
i cant find these specifications anywhere for this medion defender p10 3060
sweetpoison
Message 4 of 7
Message 4 of 7
TGP... I would never guess it... (https://acronyms.thefreedictionary.com/TGP)
Anyway, here are some basic information about video card RTX 3060 mobile
https://www.videocardbenchmark.net/gpu.php?gpu=GeForce+RTX+3060+Laptop+GPU&id=4342
Max TDP: 115 W
Hope that gives the answer you are looking for.
Cheers
sixsonic
Message 5 of 7
Message 5 of 7
@sweetpoison thanks for your reply, are you sure this benchmark is from the Medion Erazer Defender P10?
sweetpoison
Message 6 of 7
Message 6 of 7
@sixsonic
No, it is a benchmark for RTX 3060 mobile GPU, sort of baseline numbers (including the score).
Since the video card is build in motherboard you can't predict how much power will use (compared to desktops) so the GPU specs are the closest info you can get.
Cheers
sixsonic
Message 7 of 7
Message 7 of 7
6 REPLIES 6
