le 16.04.2022 16:14
le 16.04.2022 16:14
Hello!
I've noticed that I'm not the only one with this issue. I recently bought this PC only for my excitement to be interrupted by regular, random reboots.
The screen goes black without the PC shutting down and then turns back on like it had just restarted.
Read that it was a BIOS issue and that there was an admin handing out fixed versions of the BIOS. I would be more than pleased to have solution to this.
Current BIOS: E7C79WOX.205 06/11/2021
MSN: 10024085
Waiting for a response,
Spruce.
le 13.07.2022 08:19
le 21.10.2022 22:50
le 21.10.2022 22:50
@Andi, can i please get the same BIOS update!
I have the exact same specification as this post.
Me and my friends have spent months of troubleshooting, and after a few months we found this post.
However, in none of the post i could find the actual update.
It would be much appreciated if i could get the update as well.
Also, is there a reason this update isn't public? as it seems every system has the same problem?
Kind regards,
Redmans.
