MEDION Erazer Hunter X62 (MD35081) randomly reboots
11 RÉPONSES 11
Spruce
Message 1 sur 12
4 589 Visites
Message 1 sur 12
4 589 Visites
Hello!
I've noticed that I'm not the only one with this issue. I recently bought this PC only for my excitement to be interrupted by regular, random reboots.
The screen goes black without the PC shutting down and then turns back on like it had just restarted.
Read that it was a BIOS issue and that there was an admin handing out fixed versions of the BIOS. I would be more than pleased to have solution to this.
Current BIOS: E7C79WOX.205   06/11/2021
MSN: 10024085
Waiting for a response,
Spruce.
11 RÉPONSES 11
ConnyAndersson
Message 11 sur 12
841 Visites
Message 11 sur 12
841 Visites
Hello @Andi!
 I hope you can help me with my issue?
my medion i randomly rebooting.
my computer is erazer hunter x62 MD35081, 10024085
my motherboard is;
MPG z490 gaming edge wifi.
Do you know where i can find bios update?
Thanks Conny
Redmans
Traveler
Message 12 sur 12
712 Visites
Message 12 sur 12
712 Visites
@Andi, can i please get the same BIOS update!
I have the exact same specification as this post.
Me and my friends have spent months of troubleshooting, and after a few months we found this post.
However, in none of the post i could find the actual update.
It would be much appreciated if i could get the update as well.
Also, is there a reason this update isn't public? as it seems every system has the same problem?
Kind regards,
Redmans.
11 RÉPONSES 11
