MEDION ERAZER ENGINEER P10 (MD35007) | SSD UPGRADE |
5 REPLIES 5
tqo
Message 1 of 6
Message 1 of 6
Yo guys, i noticed theres another slot for a nvm ssd on the motherboard and I want to buy another one. Does it matter if it's a M.2 SATA 3.0 or M.2 2280?
1 ACCEPTED SOLUTION
Message 2 of 6
Message 2 of 6
Hi @tqo and welcome
you have a SSD M.2 (2280) 512G PS5012-E12S B27A PCIe 22.6
your Internal Connectors:
  • * 1 x M.2 M2_1 (2260 and 2280 size with flexible standoff, SATA mode only)
  • * 1 x M.2 M2_2 (for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280)
so only one SATA fits
bye Fishtown
5 REPLIES 5
Message 2 of 6
Message 2 of 6
Hi @tqo and welcome
bye Fishtown
tqo
Message 3 of 6
Message 3 of 6
Ahhh ok, thanks for the help! 👍
ridensuto
Message 4 of 6
Message 4 of 6
Hi, I cant find out what kind of SSD M2 I can get. I know that this one is in Norgwegian, but can you try and see if you understand the specs? And come back to me if I can use it? Thanks 🙂 https://www.power.no/data-og-tilbehoer/datakomponenter/harddisk/samsung-980-pcie-30-nvme-m2-ssd-500-...
tqo
Message 5 of 6
Message 5 of 6
I don't think you can use that one, i bought a similar one, but with slightly higher capacity and it wasn't supported by the motherboard. Ended up changing the motherboard to a asus z490-g , the mb that comes with the computer is extremely limited and outdated.
MrErnest
Message 6 of 6
Message 6 of 6
I found one that worked 🙂 One TB ekstra storage now 🙂 This is the one that worked for me: https://www.power.no/data-og-tilbehoer/datakomponenter/harddisk/adata-ultimate-su800-m2-1tb/p-593819...
5 REPLIES 5
