Insane hot CPU Erazer Deputy P60
5 REPLIES 5
Vontrox
Message 1 of 6
Message 1 of 6
Hi,
Is it normal that my P60 runs at full fan speed and the CPU still has a temperature of 98 degrees celcius... Not to mention the insane noise it makes with the fans....
I fear that this CPU burns broken in two months at this rate...
5 REPLIES 5
RAZZ
Message 2 of 6
Message 2 of 6
Good morning @Vontrox ,
The temperatures do not look normal and can be dangerous to you unit, please ensure that the unit is used on a hard surface and that the vents are not block, I would suggest contacting Medion directly to have your unit assessed and repaired if needed, as over time this will cause serous damage to your unit running at these high temperatures.
Please find Medion UK's contact details below- You can call or email with your all unit details and a copy of your proof of purchase so Medion can register your unit and assist in any other questions.
MEDION Electronics UK
120 Faraday Park
Faraday Road
Dorcan
Swindon
SN3 5JF
Tel: 0333 3213106
Web: www.medion.co.uk
Email: hotline.email@medion.com
Vontrox
Message 3 of 6
Message 3 of 6
Hi Razz,
Thanks, but i live in the Netherlands... Any idea where i can make such report there ?
RAZZ
Message 4 of 6
Message 4 of 6
dear @Vontrox
Please contact Medion NL-  https://www.medion.com/nl/service/
Thanks
RAZZ
Message 5 of 6
Message 5 of 6
dear @Vontrox
the Dutch community forum may be able to assist as well
https://community.medion.com/t5/Nederlands/ct-p/NL
Thanks Sam
Vontrox
Message 6 of 6
Message 6 of 6
Thanks  for the info! Will continue my search there !
5 REPLIES 5
