How to update the BIOS and firmware on a Erazer Engineer P10 (35007)
5 REPLIES 5
UmamiBanani
Message 1 of 6
Message 1 of 6
I just purchased a Medion Erazer P10 (35007). The first thing I do with a preinstalled PC is to do a clean install of Win10, update and install drivers. I cant seem to find an update tool for the BIOS. The BIOS seems to be delivered by American Megatrends.
Does this PC come with a preinstalled control center software? I forgot to check before I wiped it.
Also, I wanted to update the firmware on the Zotac RTX 3060TI to enable reziable bars. The software from Zotac terminated with a message about this GPU not being one of theirs. A little confused by this as it says Zotac with big letters on the GPU.
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 4 of 6
Message 4 of 6
Hi @UmamiBanani ,
the firmware update for our products which use W10 are provided via Firmware update function on device manager.
There should be no Control center preinstalled with your unit, and please find below information on your MB:
CPU socket: Socket LGA 1200 (65W max.)
Chipset: INTEL FH82B460
Type: internal
Technical kernel data: ECS B460H6-EM * RAM: max. 32 GB (2 slots) * Form factor: microATX
Interfaces / Connectivity: Back panel:
* 2x USB 2.0 Type-A ports
* 2x USB 3.0 Type-A ports
* 1x USB 3.1 Gen2 Type-A port
* 1x USB 3.1 Gen2 Type-C port
* 1x DisplayPort
* 1x HDMI
* 1x LAN (RJ45) port
* 3x OFC audio jacks
Internal Connectors:
* 4 x SATA 3 ports (4x black color)
* 1 x M.2 M2_1 (2260 and 2280 size with flexible standoff, SATA mode only)
* 1 x M.2 M2_2 (for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280)
* 1 x M.2 M2_3 (E-Key 2230 for WLAN only)
* 1 x CPU 4PIN Fan header CPU_FAN (red)
* 1 x Sys FAN 4PIN SYS_FAN (white)
* 1 x Front Audio F_AUDIO with black plastic header
* 1 x Frontside USB: Cardreader with black plastic header (one port only),
* 1 x USB3.0 H10x2 front header F_USB31_12 (Intel pin out)
* 1 x Front_Panel header F_PANEL black plastic header
* 1 x 8PIN ATX 12V connector ATX_12V
PCIe slots:
* 1 x PCIe x16
* 1 x PCIe x1
Regards,
Gehringer
5 REPLIES 5
Gehringer
Retired
Message 2 of 6
Message 2 of 6
Hi @UmamiBanani ,
can you please provde the MSN number of your unit so I can check with MB it comes with?
Regards,
Gehringer
UmamiBanani
Message 3 of 6
Message 3 of 6
The MSN: 10023976
Gehringer
Retired
Message 4 of 6
Message 4 of 6
Hi @UmamiBanani ,
Type: internal
* 1x DisplayPort
* 1x HDMI
PCIe slots:
* 1 x PCIe x16
* 1 x PCIe x1
Regards,
Gehringer
UmamiBanani
Message 5 of 6
Message 5 of 6
Thank you @Gehringer
Do you also have information on whether Nvidia resizable bar function for the 30-series graphics cards is enabled on this motherboard?
Gehringer
Retired
Message 6 of 6
Message 6 of 6
Hi @UmamiBanani ,
unfortunately, this MB does not have this function enabled.
Regards,
Gehringer
5 REPLIES 5
