How to limit charge to 60 or 80%? Medion Erazer Deputy P30
1 ANTWOORD 1
BasicallyAFossi
Bericht 1 van 2
1.240 Weergaven
Bericht 1 van 2
1.240 Weergaven
How do you limit the charge when plugged in to 60 or 80% like other manufacturers? Currently the only options is either to unplug, reduce performance and constantly cycle the unit, or leave it stuck at 100% charge, both of which aren't great for battery life.
Is there any way to limit the charge on this model?
1 ANTWOORD 1
Mastermind
Bericht 2 van 2
1.113 Weergaven
Bericht 2 van 2
1.113 Weergaven
Hi @BasicallyAFossi ,
if charging limits can be adjusted with one of the Deputy P30 laptops,you find this information in the Bios settings. Unfortunately we have no such unit in hand, so yout could give it a try.
Cheers
1 ANTWOORD 1
