How is MEDION ERAZER P6705 (MD61105)?
1 REPLY 1
natimewad28
Message 1 of 2
Message 1 of 2
How does it perform at gaming and others tasks?
Here are some specifics of the hardware:
Intel Cor i5-8300H, 16 GB RAM, 1 TB HDD, GeForce® GTX 1050 Ti.
1 REPLY 1
sweetpoison
Message 2 of 2
Message 2 of 2
Welcome to the forum,
Can't answer to your question since my laptop is slightly below in terms of components. Yet, I would recommend a consideration for Medion Crawler E10 Core i5-10300H 8GB 256GB SSD 15.6 Inch GeForce GTX 1650 Ti Windows 10 Gaming Lapt... based on: https://www.cpubenchmark.net/compare/Intel-i5-8300H-vs-Intel-i5-10300H/3254vs3646 and https://www.videocardbenchmark.net/compare/GeForce-GTX-1050-Ti-(Mobile)-vs-GeForce-GTX-1650-(Mobile)...
All that for less than £200 difference.
As a GTX1050  user I can tell that is a videocard near to the bottom of "good video card list" and that means in game low/maybe average quality settings.
Anyway, consider that GTX 1050 (TI or not) is close to minimal requirement for modern games.
Maybe some one who actually have an ERAZER P6705 in use can come up with more precise information about gaming performance.
Cheers.
1 REPLY 1
