Horrible fan noise from new MEDION ERAZER ENGINEER P10 MD35007 (with 3060ti)
24 ANTWORTEN 24
Noel
Nachricht 1 von 25
14.073 Aufrufe
Nachricht 1 von 25
14.073 Aufrufe
Hello,
I've recently purchased a gaming desktop from Medion (ERAZER ENGINEER P10 MD35007). There is some unbearable loud and noise (although it sounds functional) coming from the back of it when the GPU is under load. I can't determine for sure if it comes from the Power Supply or from the Fan(with blue led) just underneath it. So far I'd say 60% chance from the power supply.
I reduced the fans(with blue leds) rotation to 600-700 rpm wih the help of Bios modifications and a software but it doesn't fix the issue at all.
i really don't want to send the tower back since I like the components and design and I don't want to wait 3 weeks for a refund (just sent back another desktop last month because the GPU didn't matched the description).
So what are my options and what could Medion do to help ?
Should I change the fans and if it doesn't solve the issue, change the power supply ?
What do you think ?
24 ANTWORTEN 24
MrErnest
Nachricht 11 von 25
4.205 Aufrufe
Nachricht 11 von 25
4.205 Aufrufe
I problems with heat in my computer. But for now, it seems to bee under controll. Changed the fans with Noktua ones. Since I did not like the bright blue light. GPU temp is a bit high, but stay at 80 degrees while playing games so I guess its normal. Seems like changing the fans had no effect. And also moving one of the fans to the bottom of the cabinett (where the dust filter is) also had no effect. But like you say, as long as it works leave it alone.....
Shal3R
Nachricht 12 von 25
4.187 Aufrufe
Nachricht 12 von 25
4.187 Aufrufe
Hi.
I have same problem with my x10.
It's the PSU Fan that makes that terrable noise when it's under load.
Im planing to buy new motherboard new ram sticks and new PSU cuz these things in erazer enginer models really sucks. and should be repleaced to better ones.
Manu445
Nachricht 13 von 25
3.804 Aufrufe
Nachricht 13 von 25
3.804 Aufrufe
did you pc do this
https://www.youtube.com/watch?v=TdG7vVbeKo8 is the gpu
Shal3R
Nachricht 14 von 25
3.796 Aufrufe
Nachricht 14 von 25
3.796 Aufrufe
Hi.
No. Cuz sound was from PSU till one day PC died. So i bring it to warranty and after fix they replaced Processor. Motherboard and SSD. So i think that faiuty Motherboard was trying to get out more than PSU can handle when it was under the load.
Now everything is greate.
UmamiBanani
Nachricht 15 von 25
3.792 Aufrufe
Nachricht 15 von 25
3.792 Aufrufe
I got a good deal on a EVGA SuperNova PSU. The awful noise went away and all seems good afterwards. The GPU from Zotac seems to be notorius for being loud though.
grejon
Nachricht 16 von 25
3.763 Aufrufe
Nachricht 16 von 25
3.763 Aufrufe
I have the same issue, it's an annoying sound but I guess I can accept it for now.
Shal3R
Nachricht 17 von 25
3.759 Aufrufe
Nachricht 17 von 25
3.759 Aufrufe
If you have warranty then just return it. It should not sound lika a jet engine.
MrErnest
Nachricht 18 von 25
3.737 Aufrufe
Nachricht 18 von 25
3.737 Aufrufe
What did the temperature on the GPU run at? And was it enough cooling to have the original fans in the computer housing? For cooling? Did you have any temperature problems?
grejon
Nachricht 19 von 25
3.690 Aufrufe
Nachricht 19 von 25
3.690 Aufrufe
Has anybody else ever tried swapping out only the PSU to see if it alleviates the problem or would the motherboard have anything to do with this problem and need to be swapped also?
Shal3R
Nachricht 20 von 25
3.679 Aufrufe
Nachricht 20 von 25
3.679 Aufrufe
I waited till my PC died. Ehen i got it back from warranty. They repleaced Motherboard, SSD and CPU. After that PSU started to work normal. Im guessing it's motherboard pushes PSU to work at maximum or more.
24 ANTWORTEN 24
