on 21.12.2024 14:37
on 21.12.2024 14:37
Hey. I'm trying to change the M.2 chip but I'm having problems getting windows installed again.. I've tried and googled for answers and tried various drivers as it seems like it can't find drivers. since I keep getting the error message that it is missing drivers.
I also can't choose which disk bios to start from. in boot manager..
The new m.2 chip I use is the KC3000 PCI 4.0 NVMe M.2 which I also use in my desktop computer.
I have tried to clone the old chip onto an external hard drive and then clone from it to the new chip. But it still won't install either windows 10 or 11
BIOS INFO:
on 26.12.2024 16:30
on 26.12.2024 16:30
#FIXED!
I ran into an issue when trying to install Windows 11 on my Kingston KC3000 PCIe 4.0 NVMe M.2 SSD. The Windows installer couldn't detect the SSD and kept asking for drivers. Standard drivers I found online didn’t work. After some trial and error, I resolved the issue by using NTLite to integrate the necessary NVMe drivers into the Windows installation USB. Here's the step-by-step process I followed:
Download the necessary tools:
Install NTLite:
Load the Windows ISO in NTLite:
Add the NVMe Drivers:
Create a New Windows Installation ISO:
Create an Updated Installation USB:
If the Windows installer cannot detect NVMe SSDs (like the Kingston KC3000), the solution might be to integrate the drivers into the installation image using NTLite. This can be especially helpful for systems with older BIOS or missing NVMe support.
