GPU/CPU Upgrade Medion Erazer P7647
3 REPLIES 3
nigel2392
Message 1 of 4
Message 1 of 4
Hey! I have a couple of questions regarding the Medion Erazer P7647 with an I5-7200U.
Would it be possible to upgrade my CPU (I5-7200U) to a 4 core 8thread processor like the I7-8565 CPU?
If not, would an upgrade to the I7-7200U work? Would I benefit from a I7-7200U as opposed to my I5-7200U?
Also, would it be possible to upgrade the GTX950M to a 980M (made for brands like Msi, Dell, Alienware)? Would it work?
Or could I even upgrade it to a GTX1060M?(Made for before mentioned brands.) Would it work?
Will anything require a bios update? Where can I find such updates.
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @nigel2392 and welcome to the Forum!
Can you please provide the MSN number of your unit?
It is an 8-digits number (normally starting by 100, 300 or 500) that you will find underneath the product
Regards,
Gehringer
nigel2392
Message 3 of 4
Message 3 of 4
The serial number is 185PE6004770.
Thankyouu!
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @nigel2392 ,
as you have a notebook, the video card and the CPU are onboard.
We can't recommend nor guarantee the replacement of these parts nor any other board level changes/repair.
Also, you may not be able to find official BIOS upgrades
Regards,
Gehringer
3 REPLIES 3
