Erazer fan extremely loud
7 ANTWOORDEN 7
BobDylan1966
Bericht 1 van 8
9.486 Weergaven
Bericht 1 van 8
9.486 Weergaven
Hello
I bought my son a Erazer Gaming Notebook Crawler E10. From the moment we bought it (therefore the problem shouldn't be dust), the fan has been extremely loud whenever he plays fortnite on it - it is so loud that he can barely hear his friends!
Is this normal?  Is there anything I can do in settings? I couldn't find any options regarding the fan.
Sorry, I know nothing about computers so please speak to me as if I'm an idiot if you are kind enough to reply!
Many thanks
7 ANTWOORDEN 7
mats749
Bericht 2 van 8
9.418 Weergaven
Bericht 2 van 8
9.418 Weergaven
Hi @BobDylan1966
Welcome to the community,
The crawler E10 may have the command center installed, This command center will allow you to adjust the fan profiles. You can type "Command center" into the search box on the task bar and this will allow you to open the program.
When gaming, the fans will be on however there are a lot of variables involved.  For example, If the graphics settings are too high, it will cause the GPU to work harder which will cause more heat generation in turn the fans to work harder.
If you feel like the fan noise is excessive or strange, please contact your local medion service support.
Thanks
Mats749
BobDylan1966
Bericht 3 van 8
9.408 Weergaven
Bericht 3 van 8
9.408 Weergaven
Thanks for your reply.
It doesn't seem that my laptop has a 'command center' or a 'control center'.
You say contact "your local medion service support" - how does one do that?
It's very frustrating, we can't even hear films/programmes properly as the fan is so loud!
BobDylan1966
Bericht 4 van 8
9.406 Weergaven
Bericht 4 van 8
9.406 Weergaven
Actually, I think I have found it!  Is this it?   Needless to say, I'm not overly sure what I should do with it!
Thanks again
mats749
Bericht 5 van 8
9.352 Weergaven
Bericht 5 van 8
9.352 Weergaven
Hi @BobDylan1966
You'll be able to set the fan profile to custom and adjust the fan speed, Although I see that its already set on Automatic which will use the best fan profile for the temp of the computer. What temperatures are you seeing when playing a game ?
Thanks
mats749
BobDylan1966
Bericht 6 van 8
9.347 Weergaven
Bericht 6 van 8
9.347 Weergaven
Thank you for replying, I appreciate it.
While playing with the fan being loud, On the blue on it says 81 degrees GPU. And the pink one says 85 degrees CPU.
is that normal?
dofusanney
Bericht 7 van 8
6.083 Weergaven
Bericht 7 van 8
6.083 Weergaven
Hi, how did you find this? I'm having issues with one of my fans being loud on the Erazer Bandit P20 Gaming PC. Thanks
Mastermind
Bericht 8 van 8
5.488 Weergaven
Bericht 8 van 8
5.488 Weergaven
Hi @dofusanney ,
pls remind that we´re now talking about one ERAZER laptop an onr ERAZER DT PC, which are two different products.
If you nleave us the 8-digit article number of your PC (starting with 1002xxxx) we can provide further assistance.
Cheers
7 ANTWOORDEN 7
