Erazer X25 Beast 3070 Ram Upgrade
1 REPLY 1
SC23
Message 1 of 2
Message 1 of 2
Hi,
I want to upgrade the RAM in my unit however I'm unsure what type would work correctly and give good performance this is my unit's MSN :
30033306
1 REPLY 1
Message 2 of 2
Message 2 of 2
Hi @SC23 ,
your unit is running with 2 pcs 8 GB Hynix DDR4 SO-DIMM (PC4-25600/ 3200 MHz) HMA81GS6DJR8N-XN modules.
Remind that both available RAM slots are currently alrady covered so a pair of new RAM modules (max. capacity 2 x 32 = 64 GB) should do as long as you buy identical ones.
Feedback very aplpreciated.
Cheers
1 REPLY 1
