Erazer P10 Specialist Ram upgrade
4 REPLIES 4
Polaris741
Message 1 of 5
Message 1 of 5
Hello,
Can anyone tell me if the disassembly of the p10 specialist is easy ? I would like to switch memories for 2x16gb .... If someone already did it can he tells me how it went ?
Thanks alot
4 REPLIES 4
Message 2 of 5
Message 2 of 5
@Polaris741
We would like to help, but fiirst we need the MSN number and the MD  number.
They are on a sticker on the bottom of the housing, ifyou talk abaot a desktop model, or underneath the laptop.
cheers, daddle
Polaris741
Message 3 of 5
Message 3 of 5
MD62477 thank you
Message 4 of 5
Message 4 of 5
This number is not recognized by the database.
Please check again and name the MSN number as well. It is a 8 digit (article) number.
Is  it a desktop or a laptop? Probably a laptop.
Message 5 of 5
Message 5 of 5
@Polaris741
The only Erazer P10 Specialist I did find is this one:
-->  https://www.medion.com/de/service/product-detail/30034142
Check the Technical Specifikaton.
It says for RAM:
Equipped 2x 8 GB DDR4 SO-DIMM (PC4-25600 / 3200 MHz) (2/2 Slots covered; 64GB max.)
You could insert 32 GB x2.
4 REPLIES 4
