ERAZER X7853 MD60605, Bios + Original EC, help!
15 RÉPONSES 15
nicke85
Message 1 sur 16
11 949 Visites
Message 1 sur 16
11 949 Visites
Hello,
I have Medion Erazer X7853 MD60605, and after i updated wrong EC from Medion service i have to find way to bring notebook in life.
After two months i ordered tools to install EC file after nobody knows how to help me. I have now XMG Bios in Erazer and XMG EC.
But i lost my blue frame around mousepad and 2 of 3 audio ports dont have light.
I want to turn back to original Medion EC and Bios.
Does anybody have backup of EC file or knows where to download that EC file for Erazer X7853.
Kind regards
15 RÉPONSES 15
nicke85
Message 11 sur 16
11 803 Visites
Message 11 sur 16
11 803 Visites
I have solved problem,
Have found the lastest Medion Erazer X7853 (X7851) bios and installed it.
Blue mouse frame LED can be enabled / disabled by Fn+2, and fan EC / MAX switch with Fn+1.
Also it works with EC file from XMG, bios just must be from Medion 🙂
Balises (1)
tipsythomas
Message 12 sur 16
3 760 Visites
Message 12 sur 16
3 760 Visites
hi I just bought a Corsair ram upgrade for my medion guardian x10 but it won't use full speed specs as no xmp option in bios.
The xmg neo 15 is the same base laptop but there bios allows 2933mhz ram.
Do you know what I would need in order to xmg my laptop like what you did to yours.
Ta
Gehringer
Retired
Message 13 sur 16
3 752 Visites
Message 13 sur 16
3 752 Visites
Hi @tipsythomas ,
I am marking @nicke85 on this conversation so he should receive a notification.
Regards,
Gehringer
milswugi
Message 14 sur 16
3 304 Visites
Message 14 sur 16
3 304 Visites
hi there guys. how did you manage to install that version of the bios? can you guide me through the process? i have a x7853 with gtx1070.
thank you!
milswugi
Message 15 sur 16
3 303 Visites
Message 15 sur 16
3 303 Visites
@nicke85 @Gehringer  can one of you help me with flashing my bios? i should mention that i allready downloaded the xmg bios files. one problem i have. i have to flash it without having access to bios(the laptop starts but i have no image. i know that the laptop works because it stopped working when i switched the video card from mdhybrid to discrete - i think the gtx1070 has a problem and it was working on the integrated intel one) .
tipsythomas
Message 16 sur 16
3 297 Visites
Message 16 sur 16
3 297 Visites
Just letting you know I never got a response and that was from April.
15 RÉPONSES 15
