ERAZER RECON P10 loud fans and noise
1 REPLY 1
michaelatb
Message 1 of 2
Message 1 of 2
Hello,
I'm having some trouble with my PC it's very very noisy and weird ramping up and down.
I can't seem to be able adjust the fan curves of this PC, no available software anywhere.
Fancontrol wont recognize the fans correctly, the bios are very old (Blue & Grey) bios.
No additional software or downloads to be available on the medion website.
MD35177
MSN: 10024292
1 REPLY 1
Mastermind
Message 2 of 2
Message 2 of 2
Hi @michaelatb ,
first of all I´d like to ask you, if the issues appeared from day one, or somewhen later (maybe as a result of an SW update)?
Pls check and provide your current Bios version (like V 1.12) to see,if it can be updated?
Cheers
1 REPLY 1
