ERAZER ENGINEER P10 MD35166 NL. Specifications online?
1 REPLY 1
RafterX
Message 1 of 2
Message 1 of 2
Hi community
I have this pc: PC ERAZER ENGINEER P10 MD35166 NL. MSN: 1002 4236
I cannot find exact specifications on the Medion site, when I click the specifications TAB, it doesnt show specs, and it is hard to find the precise specs online, as so many numbers and models exists.
I know I can use a program on the PC to show me the specs, but I just want to know exactly what this model is supposed to include, online.
Can you help? 🙂
Thanks.
RafterX
Tags (1)
1 REPLY 1
Message 2 of 2
Message 2 of 2
@RafterX
Er zijn noog geen volledige specs te vinden, alleen zo veel:
-> https://www.medion.com/de/service/product-detail/10024236
-->  https://cdn.medion.com/downloads/anleitungen/flyer_20070296.pdf
De mainboard is een B460H6-EM
lnternal / ext. connectors
Back Panel:
* 2x USB 2.0 Type-A ports
* 2x USB 3.0 Type-A ports
* 1x DisplayPort
* 1x HDMI
* 1x LAN (RJ45) port
* 3x OFC audio jacks
Internal Connectors:
* 4 x SATA 3 ports (4x black color)
* 1 x M.2 M2_1 (2260 and 2280 size with flexible standoff, SATA mode only)
* 1 x M.2 M2_2 (for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280)
* 1 x M.2 M2_3 (E-Key 2230 for WLAN only)
* 1 x CPU 4PIN Fan header CPU_FAN (red)
* 1 x Sys FAN 4PIN SYS_FAN (white)
* 1 x Front Audio F_AUDIO with black plastic header
* 1 x Frontside USB: Cardreader with black plastic header (one port only),
* 1 x USB3.0 H10x2 front header F_USB31_12 (Intel pin out)
* 1 x Front_Panel header F_PANEL black plastic header
* 1 x 8PIN ATX 12V connector ATX_12V
PCIe Slots:
* 1 x PCIe x16
* 1 x PCIe x1
En het  heeft two slots voor ram  modules:
1x 8 GB DDR4-SDRAM (PC4-21300 / 2666 MHz) Dual Channel Memory (1/2 Slots covered; 32 GB max.)  ( Dit  is door mij alleen maar aangenomen)
Ik hoop het helpt een beetje.
Groetjes, daddle
1 REPLY 1
